Z banding at different heights
Charlie paton
(@charlie-paton)
I3 mk3s fresh build, petg using prusament petg preset, built 2 and only one has these z bandings at random points where a layer is much wider than others, the print on the left also has the line more squashed as it goes further right
Respondido : 29/06/2021 9:51 am
Miembro
RE: Z banding at different heights
I am not sure this is Z Banding.  Can you post more photos?  It might also help if you upload the sliced 3MF file zipped so we can look at it.
Respondido : 29/06/2021 10:16 am
Charlie paton
(@charlie-paton)
Cupholder
Thanks for the reply, above is the ZIP file from the sliced model, i will upload more photos from my phone in my next reply
Respondido : 29/06/2021 11:40 am
Charlie paton
(@charlie-paton)
@cwbullet
The last photo is the same file where the one on the left was stopped early when I noticed the line that had formed
Respondido : 29/06/2021 11:45 am
Dan Rogers
(@dan-rogers)
Other than the horizonal line (looks like slight layer shift) I am not sure what defect I am looking for.
Respondido : 01/07/2021 9:35 am
Miembro
@charlie-paton
I think @dan-rogers is correct.  I do not see it from all angles.  Wierd.  Have you tied to print a different but similar-sized object?
Respondido : 01/07/2021 9:42 am
Charlie paton
(@charlie-paton)
@cwbullet
Not any different models similarly sized but the print I did immediately after the larger print was another copy of the first one, same gcode and it came out completely fine
Respondido : 01/07/2021 10:04 am
