Z banding at different heights
I3 mk3s fresh build, petg using prusament petg preset, built 2 and only one has these z bandings at random points where a layer is much wider than others, the print on the left also has the line more squashed as it goes further right
RE: Z banding at different heights
I am not sure this is Z Banding. Can you post more photos? It might also help if you upload the sliced 3MF file zipped so we can look at it.
Thanks for the reply, above is the ZIP file from the sliced model, i will upload more photos from my phone in my next reply
Other than the horizonal line (looks like slight layer shift) I am not sure what defect I am looking for.
@charlie-paton
I think @dan-rogers is correct. I do not see it from all angles. Wierd. Have you tied to print a different but similar-sized object?
@cwbullet
Not any different models similarly sized but the print I did immediately after the larger print was another copy of the first one, same gcode and it came out completely fine
