Z-Axis noise. Is this normal?
Muldjord
(@muldjord)
I've meticulously built my Prusa i3 MK3S+ about a month ago, and I've been having a lot of fun printing things. BUT! The Z-Axis is VERY noisy, and it seems to only (or mostly) be coming from the left stepper motor. I asked a friend if I could hear his printer (which is an MK3S) and it is completely silent doing the same Z-Axis movements. This led me to conclude that something is wrong with my left stepper motor. But before I dig deeper, I'd like to hear some opinions from other MK3S+ users.
So, is this normal?
Do I need a replacement stepper motor? I've tried loosening some screws slightly and adjusting the cap in front of the motor, to see if that was making the noise. But nothing helps. Belt tension is also perfect, smack in the middle of the sweetspot when testing with a PETG printed version of this.
Publié : 16/11/2021 3:05 pm
Dan Rogers
(@dan-rogers)
There is no Z belt ...
The noise will come from the linear bearings that ride on the veritical rod.  If you lubricate them (pack them with grease) before you put the printer together, you won't get that noise.  The only way to fix it is to take it back apart, and lubricate the bearings and then put it back together.
Publié : 17/11/2021 9:24 am
Muldjord
(@muldjord)
Thank you for your input. You seem very certain about this. Have you encountered this exact noise? I've tried greasing the rods, although only by applying it to the rods and moving the Z-Axis up and down several times. It does not change the sounds at all. And it very distinctly seems to come from the left stepper motor.
The reason I am asking so specifically is to avoid taking my printer apart unless it is absolutely necessary. 🙂
Publié : 17/11/2021 12:11 pm
BogdanH
(@bogdanh)
RE: Z-Axis noise. Is this normal?
Posted by: @muldjord
I've meticulously built my Prusa i3 MK3S+ about a month ago....
If you followed this step exactly, then you did it wrong. Correct way is:
1. Use holes without thread!
2. Do NOT fully tighten those two screws!
Trapezoidal nut must have just a slight free play horizontally -you should be able to "rotate" it by applying a little force. Means, tighten the screws just enough, so there's no vertical play. Again, this can only be achieved, if holes without thread are used.
-and Z-axis noise will gone.
Is hard to believe.. Prusa is assembling that trapezoidal nut in wrong way (at least that was the case with my pre-assembled Mini).
[Mini+] [MK3S+BEAR]
Publié : 17/11/2021 1:19 pm
Muldjord
(@muldjord)
Thank you for the suggestion. Turns out my right trapezoidal nut was fastened through the threaded holes so I unscrewed it, turned it slightly to align with the non-threaded ones, and screwed it back in place. I already made sure that my trapezoidal nuts aren't too tight. They weren't before either. I even tried loosening them quite a bit. Unfortunately this made no difference to the noise at all. 🙁
I even ran the full calibration again to ensure the level of the two side stepper motors. This also made no difference.
Publié : 17/11/2021 1:56 pm
Dan Rogers
(@dan-rogers)
That noise is awful - no idea what it is.
I would not run a printer that sounds like that.  It won't be long before the problem reveals itself in a most expensive way.
Publié : 18/11/2021 10:02 am
Muldjord
(@muldjord)
By the way, in case it isn't clear, I am only talking about the wrrrrrrrrrrr sound in the video. The clacking sound is just me turning the knob to get the Z-Axis to move.
Publié : 18/11/2021 11:18 am
Muldjord
(@muldjord)
Just did some further testing today. I moved the Z-Axis up and down and noticed that the left-most stepper motor got hot quite quickly, while the right-most stepper motor did not. I've contacted Prusa support.
Publié : 18/11/2021 1:55 pm
1 personnes ont aimé
Pulltab
(@pulltab)
Did you ever find out where the noise was coming from?  I'm experiencing the same noise.
Publié : 09/01/2022 11:33 am
Muldjord
(@muldjord)
No, unfortunately my MK3S+ is simply noisy in comparison with my friend's MK3S. Potentially it could mean a regression due to some changes in how they are designed around the print bed and possibly the bearings. I am in no way knowledgable enough to say anything meaningful about that.
SO! Take that with a large spoon of salt, as this is based on my personal assessment of two printers only. It might just well be because they are simply intricate machines and resonances can be caused by all sorts of weird things due to minute differences in how my friend and I put them together.
Prusa sent me a new Z-Axis stepper motor after a bit of back and forth with the support, and while it did help a bit, it didn't remove the harsh noises in a way that would make me say it's "fixed". So I've decided to simply live with it.
Luckily it prints perfectly due to me being extremely meticulous when building it. So I'm in no way disappointed with my printer. It's just that I live in an appartment complex, and after hearing my friend's MK3S it is very clear to me that my printer is simply noisy in comparison. But that's just how it is, nothing I can do about it unless I want to take it all apart and hope that the simple fact that it got taken apart and put together again, would change some resonances for the better.
A quick note: My printer is A LOT noisier when using stealth mode. So I never use it. I'm not sure if that's normal either but it suggests to me that there is something on my printer that resonates more than it should, as "stealth mode", I would assume, should be less noisy than normal mode. For me it is not. It sounds like someone stepping on a cat repeatedly when I use "stealth mode".
Publié : 09/01/2022 6:42 pm
baeru
(@baeru)
Ich habe einen neuen neuen mk3s+ gekauft. Wenn ich von Hand bediene sind die Geräusche der Z Achsen normal. Wenn ich ein Stück drucke
macht er beim Anfahren Schnellgang ziemlich laut. Ich bin ratlos!!??
Publié : 15/02/2022 9:24 am
theaecassociates
(@theaecassociates)
I used holes without thread but still the noise is coming up
outsource architectural drafting
Publié : 21/02/2022 9:21 am
ro_qu
(@ro_qu)
I have the exact same noise, on the right side motor, any one solved it?
Publié : 29/11/2022 3:53 pm
arewhyayeenjay
(@arewhyayeenjay)
I have the same sound coming from somewhere on the LHS of the machine. If i press my finger against the x-axis motor holder (item on the left here https://help.prusa3d.com/guide/3-x-axis-assembly_167854), i can stop the noise completely. Im trying to figure out whats vibrating. Will update if i figure it out.
Publié : 20/01/2023 8:27 am
LeeroyLee
(@leeroylee)
Thank you for the video! I had exactly this same sound. In my case, it was because the screw going into the X-end idler bearing assembly had worked its way loose and was rubbing into the lead screw of the right hand side. https://help.prusa3d.com/guide/3-x-axis-assembly_167854#168110 (look at the second picture).
Publié : 21/03/2023 5:31 pm
Matt Wette
(@matt-wette)
Membre
i have vibration in z-axis movement on my MK3S+.  I rotated the black caps to put the screws through the smooth holes.  No improvement.   I wonder if the two linear z-axis bearing rods are not parallel, or the x-axis assembly is not perpendicular.
Publié : 07/06/2025 11:38 pm
Robin_13
(@robin_13)
I just rebuilt my printer using ASA parts.  I found that the X-axis rod were very tight and I had to use a clamp to get them to fit into the Z-axis mount.  I also found that the one bearing was bad and damaged the rod.  Rotated the bad part out of the bearing path and replaced the bearing.
If the rods are not fully seated in the Z-axis holders, you they will not be parallel.  Your comment makes me want to measure things closer on my printer.
Publié : 26/06/2025 12:45 am
blauzahn
(@blauzahn)
The x-axis is sensitive to tolerances in the distance between the two rods. All axes on the MK3 series are. The linear bearings are overconstrained. If the distances do not match very closely the stresses in the bearings will damage it or the rod sooner or later. The low rolling friction masks it. The bending stiffness of the rods is low. As a consequence, in the middle of the axis the stresses are lower. You can feel it more towards the ends, the Z-axis mounts. That's why they have to be printed accurately; ideally at the same time closely together on a well leveled bed. Remember that ASA has a roughly twice as high thermal expansion coefficient compared to PETG. Pressing the rods into the holes in the Z-axis mounts can crack the latter. You can calibrate them with a reamer (e.g. like this).
Several users modded their x-axis with sinter-bronze bearings. Those are even more sensitive to the distances of the rods. Years ago, there had been discussions in the German section of this Forum (see this one, especially the photo).  IMHO the seating of the lower linear bearing within the extruder should get some backlash in vertical direction in order to eliminate the constraint in that direction.
I also damaged an x-rod once. That is why I have a spare one. Just in case.
Ce message a été modifié il y a 8 months par blauzahn
Publié : 26/06/2025 5:26 am
Robin_13
(@robin_13)
Comments are interesting.  I measured the distance between my X axis rods.  0.06mm from end to end.  Well within 3D printing errors with the new ASA parts.
Publié : 26/06/2025 11:21 pm
