Z axis fail
SRohan
(@srohan)
Z axis fail
Hi all; I just finished building my Mk3S+, but I am unable to get it to pass Z axis in the wizard. I have readjusted the PINDA probe and ran the test multiple times. Of note, the machine does make a horrendous noise when moving to the very top. Can anyone offer any advice? Much appreciated! Happy Holidays!
Respondido : 18/12/2020 12:26 am
Ahmad
(@ahmad)
RE: Z axis fail
i suggest you check the nut which holding the z axis, maybe you over tied the nut, also check the nut which hold the Trapezoid nut.
the  axis should move smooth.
Respondido : 18/12/2020 1:55 pm
1 les gusta
Ahmad
(@ahmad)
RE: Z axis fail
i attached photo for the Trapezoid nut.
Respondido : 18/12/2020 1:58 pm
1 les gusta
SRohan
(@srohan)
RE: Z axis fail
@ahmad
thank you, I checked the nut carefully, and it matches your pic.
Respondido : 18/12/2020 2:10 pm
Ahmad
(@ahmad)
RE: Z axis fail
ok try to reduce all the nut which related to the z axis.
also, i think you put your issue in Mini prusa forum, i suggest you put it in the MKS3 forum. there are same issue has been face with others there.
Respondido : 18/12/2020 2:15 pm
1 les gusta
SRohan
(@srohan)
RE: Z axis fail
@ahmad
Ahh! I will head over to the correct forum then, thank you!
Respondido : 18/12/2020 3:11 pm
Karkovski
(@karkovski)
Miembro Moderator
RE: Z axis fail
Posted by: @srohan
@ahmad
I have moved the thread to the correct forum.
Respondido : 18/12/2020 3:46 pm
1 les gusta
SRohan
(@srohan)
RE: Z axis fail
Is there a difference between the axis checks in the wizard vs the ones listed and conducted under the calibration menu seperately? I am passing the separate ones, but failing the wizard every time.
Respondido : 18/12/2020 10:19 pm
Rapiddescent
(@rapiddescent)
RE: Z axis fail
Open the menu Settings>MoveAxis>MoveZ and drive the extruder to the top of the unit.
The grinding noise at the top is normal.
Then run ONLY the Z calibration in the Menu Calibration>Calibrate Z
Hope this helps, worked on my first build.
Respondido : 19/12/2020 12:43 am
1 les gusta
