Z Axis Calibration
It seems that my z-axis calibration keeps on failing. I believe I found the problem being that the housing of the hot end is small where it should be covering the whole cooling coil.
Every time I ran the z-axis calibration, it would run all the way up to the top then goes down until the probe senses the heat bed and automatically shoots out a calibration failure warning.
Am I overlooking something? Do I need to ask Prusa to print a new housing for my hotend?
Publié : 18/09/2018 4:18 am
Re: Z Axis Calibration
What are you doing ?
The top of the hotend must be going into the extruder body before mounting the extruder cover.
see https://manual.prusa3d.com/Guide/5.+E-axis+assembly/510?lang=en
Step 20 & 21
Thomas
Publié : 18/09/2018 11:27 am
Topic starter
answered:
Let me reassemble. Thanks for the tip.
Publié : 18/09/2018 7:32 pm
