[yet another] X-axis layer shift
I'm new to 3d printing world and have some issues with my brand new mk3s+ (assembled from the kit). Self-test is ok, I calibrated the first layer and all axes, all screws are properly tighten, belts tension are ~260. I have good prints and sometimes bad prints. I'm using PLA (the silver one that came with the printer and a Prusament PLA black) with the default slicer params for each material.
It seems that the opposite faces from x-axys are pretty jagged. It happend or a simple RPI case, and some taller case, while calibration cubes are perfect...
Do you have any advice?
Thank you!
Knowledge base (KB)
Look through this KB:
https://help.prusa3d.com/en/article/layer-shifting_2020/
I would check each item closely.
Hi @cwbullet,
Thanks for the response, but I already went through that material before creating this topic and check everything. There is nothing mentioned there that seems to be out of order.
I have the original spool holder and the motion of the spool is not smooth especially when the extruder moves on x-axis. How likely is to cause the issue?
Spool holder
I do not think it is the spool holder.
Loosen the 4 screws on the back of the X carriage holder
They are too tight.
@dan-rogers: Dummy question: you mean this, right?
Top two, bottom two.
Yes. Top two are most impacting. The one in the middle and the one on the bottom control the squeeze on the bottom bearing.
