Y-Axis roller screw cross-threaded and stripped
Randible
(@randible)
When mounting the Y-Axis roller to the frame, the self-locking nuts are extremely difficult to get into the hole far enough to catch the threads on the screws when securing to the frame. Unfortunately, I inadvertently cross-threaded one of those screws and the self-locking nut stripped out the hole in the 3D-printed part during tightening. Sadly, I had to destroy the printed part in order to free it from the screw because the self-locking nut could not be removed. When attempting to use an adjustable wrench to free the screw from the self-locking nut, the screw-head stripped because the Allen wrench stripped out the screw-head itself. Now I'm stuck with an unremovable screw stuck in the frame and a destroyed 3D-printed Y-Axis roller mount.
Please see attached photos.
What are the recommendations on how best to proceed?
Many thanks.
Opublikowany : 08/08/2018 6:23 am
Kazibole
(@kazibole)
Re: Y-Axis roller screw cross-threaded and stripped
Contact support, see what they can do for you. In the future, grab a longer screw to first pull in the nut into the hole, then remove and use the appropriate screw.
Opublikowany : 08/08/2018 6:27 am
