Y axis motor not smooth
Havish Netla
(@havish-netla)
When I move my y axis motor without the belt on it, it requires more force during some parts of the rotation and more in other places
Veröffentlicht : 25/07/2020 8:17 pm
RE: Y axis motor not smooth
Posted by: @netlahavish
Hello and welcome in Prusaforum!
I would check the alignment of the linear rods. If they are not parallel, the axis will jam in certain areas. Likewise, the U-bolts should not be overtightened. I would also check the linear bearings and the rods for damage. And do not forget to lubricate the bearings with the supplied Prusa grease.
Veröffentlicht : 26/07/2020 12:18 am
riomanandhar
(@riomanandhar)
Posted by: @karl-herbert
Thanks for the advice, Karl Herbert. Will definitely try as you said and update the result. Thanks again.
Veröffentlicht : 07/08/2020 3:01 pm
