[Resuelto] Y Axis jumping belt?
MrFollies
(@mrfollies)
After initially printing just fine, I did not get a chance to use my printer for a few weeks.
Now I've come back to it I'm seeing an alarming problem at the bed height check at the start of a print.
It seems a if it's hitting something and the belt is jumping the cogs?   But I can move the Y axis with octoprint just fine....
Here's a link to the video:
https://drive.google.com/open?id=10aC_xLOhUq37uadEJnKv5zhDqvIc4bd_
Best Answer by rmm200:
UBolts a bit too tight can squeeze the bearings, causing a bind.
If it is all smooth now you are fine.
Respondido : 16/09/2019 2:59 am
MrFollies
(@mrfollies)
RE: Y Axis jumping belt?
Never mind,....   Lubricant!
Respondido : 16/09/2019 5:00 am
rmm200
(@rmm200)
Don't let lubricant hide a bind.
Make sure you can manually slide the carriage to each end and it feels smooth.
Glad it is working!
Respondido : 16/09/2019 3:38 pm
MrFollies
(@mrfollies)
Posted by: @robert-rmm200
Glad it is working!
I went to the lube after I tried moving the bed manually with the power switched off.   It was 'stiff' in the middle of the bed.
After I lubed it it was very smooth,..
Are there other reasons (apart from lack of lube) that would cause the stiffness?
Respondido : 16/09/2019 11:07 pm
rmm200
(@rmm200)
Respondido : 16/09/2019 11:10 pm
