Y axis belt holder-Screw stuck?
I recently assembled the MK3S+ kit and I found that my Y axis belt tension was not sufficient. Per instructions, I tightened the screw which connects the two printed belt holders, but I forgot that it is held on the other end by a nyloc nut, thus should not screwed so far in.
I also realized the tension issue can probably be fixed by adjusting the length of belt held into the holder. The problem is I can't properly screw back in the holder without taking out the larger M3x30 screw.
Any suggestions on how to get the screw out(see picture below), or should I just try to get another set of 3D printed holders?
Respondido : 22/02/2021 5:04 pm
RE: Y axis belt holder-Screw stuck?
Tap tap tap with a small hammer. Once the nut is backed all the way off of the screw, it should come apart with some love.
Respondido : 24/02/2021 4:03 pm
