Y axis Bearings
james.r49
(@james-r49)
Y axis Bearings
I am having issue with the Y bearings being really scratchy and jittery, Prior to assembly with the U bolt I actually tested the bar and the bearing and found the movement to be really scratchy/ jittery even before assembly.
Once assembled the bars are still not moving smoothly within any of the bearings . I am convinced that this will servery impact print quality once assembled. Prusa - Please could you send me replacement bearings?
Napsal : 22/02/2019 9:52 pm
vintagepc
(@vintagepc)
Re: Y axis Bearings
Use the live chat feature in the store. This is a community forum, unless another member here takes pity on you nobody will answer your plea this way.
Napsal : 22/02/2019 9:53 pm
Chocki
(@chocki)
Re: Y axis Bearings
I too thought the same when I bought my Mk3 last October, but I oiled the bearings with Singer Sewing machine Oil and they have been perfect since, occasionally getting a drop onto the shaft then running the bearing over the oil.
They glide smoothly nowadays.
Napsal : 23/02/2019 9:03 am
james.r49
(@james-r49)
Re: Y axis Bearings
Not exactly clear where or who to contact so covering all bases. isnt that the point of these forums though
Napsal : 23/02/2019 10:54 am
