XYZ Calibration Z not going all the way up
OW
 OW
(@ow)
Just finished assembling my MK3S+ last night and am now stuck on the initial calibration steps.  Specifically the XYZ calibration where the Z axis is supposed to travel all the way to the top and rattle but it only goes a few inches up at most for me.  I have searched and tried several things but no progress yet.
I have loosened the Z motor covers, the screws on the trapezoidal nuts, and even the screws for the motors themselves as well as the top pieces where the leadscrews and smooth rods go it.  I have done the reset process and cleared all data numerous times in between trying all of these things.  I can manually jog the Z axis up and down fine.
I emailed support earlier and they suggested loosening the covers and trapezoidal nuts which I did.  I also took a short video of where it stops and replied with that as requested.  I understand with the holiday and all that support may be slower than usual so I'm not worried about that at this point but thought maybe I could get other suggestions here while waiting on support.
I just hope I don't have to disassemble too much as I just spent over 20 hands on hours putting this together and I'm not in the mood to do a lot of reassembly work.
Here is the video I sent to support: https://forum.prusa3d.com/wp-content/uploads/2022/12/Img-0235.m4v
Respondido : 23/12/2022 11:57 pm
RandyM9
(@randym9)
RE: XYZ Calibration Z not going all the way up
That seems an odd one. Did support have you re-flash the firmware?
Respondido : 24/12/2022 5:31 am
OW
 OW
(@ow)
No, but I will try that tomorrow.
Respondido : 24/12/2022 5:34 am
RandyM9
(@randym9)
Sounds good. Please let us know how you make out.
Cheers
Respondido : 24/12/2022 5:41 am
OW
 OW
(@ow)
Firmware updated and no change.  I've figured out that if I move the Z axis to the top and start the XYZ calibration it seems to proceed normally.  It found all 4 initial points then prompts me to install the steel sheet.  On that next part it fails in the back right corner saying sensor not found but I noticed an odd noise like its binding on the right side.  It almost looks like the left side is moving slightly more than the right side but I can't be sure.
I aborted the calibration and starting jogging the Z axis from the LCD and noticed that the noise happens in a certain area only.  I tried to capture it in the attached video.  So, something is binding when it is in that area it seems even with all of the screws still loose.
https://forum.prusa3d.com/wp-content/uploads/2022/12/prusa-binding.m4v
Respondido : 24/12/2022 5:46 pm
OW
 OW
(@ow)
I believe I found my issue.  After taking apart the right side of the Z axis for like the 5th time I noticed the screw head for the pulley was very close to the back of the lead screw.  I guess I didn't screw it in far enough during assembly. Tightened that down and put it all back together.  Ran through the XYZ calibration without errors and the result was X/Y axes are perpendicular!  I did another clear of all settings to start the wizard from scratch and I am now printing my benchy,
Respondido : 25/12/2022 2:19 am
1 les gusta
RandyM9
(@randym9)
That’s awesome! Glad you got it sorted.
Enjoy your new printer.
Cheers
Respondido : 25/12/2022 4:35 pm
fordville
(@fordville)
Hooray for small victories!
Respondido : 26/12/2022 11:24 pm
