XYZ calibration failed. Bed calibration point was not found.
[Rozwiązany] XYZ calibration failed. Bed calibration point was not found.
Sadolin
(@sadolin)
Just completed the assembly of my Mk3s and is now stuck in the XYZ calibration.
Is is unable to locate the calibration point in the right rear corner. It perfectly finds the 3 other points.
I have been reading through other posts, adjusted the PINDA probe height etc. but it just can´t find that one point.
Any suggestions?
Opublikowany : 03/11/2019 1:04 pm
RE: XYZ calibration failed. Bed calibration point was not found.
CHAT in the Prusa store.  They can talk you through what needs to be done.
Opublikowany : 04/11/2019 6:36 am
Sadolin
(@sadolin)
Fixed after loosening the y-belt to what I find too loose - but it works so I’m happy
Opublikowany : 04/11/2019 6:48 pm
