X-Axis Error during Self-Test / Belt Test
Durahl
(@durahl)
Watching THIS VIDEO my to an i3 MK3S+ rebuilt Printer now keeps insisting on showing my an X-Axis Error despite having 255mm of travel during Jogging with reportedly having had 229mm of Belt Length beforehand - What is going on?
Best Answer by Dan Rogers:
X axis is very sensitive to bearings on X being squeezed too tightly.  Loosen your X carriage screws three turns each and see if it goes away.
If they fall out, put them back in and only tighten the carriage a little bit - Top ones do all of the work.  The bottom ones can be almost falling out and your prints will be sweet on X.
Respondido : 06/09/2021 8:11 am
Miembro
thread
Thread that might help:
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-others-archive/self-test-error-x-axis-length/
Respondido : 06/09/2021 11:51 am
Dan Rogers
(@dan-rogers)
RE: Loosen the X carriage.
Respondido : 06/09/2021 1:12 pm
1 les gusta
Durahl
(@durahl)
That did the trick!
Thanks mate...
Since my OP I've basically taken apart like half the E and both Z-Axis and rebuilding it taking extra care with the Umbilical exiting the rear of the E-Axis to the point where I was fearing for my life for getting squatted because how tight I bound that ZipTie Area and still couldn't get it to work.
Until I loosened up those 4 screws and it worked again 🙄
Respondido : 06/09/2021 5:19 pm
