X axis belt Tension with X axis motor clicks
Flex
 Flex
(@flex)
Hello
Here is my issue. If I get my belt tension between 255-270 (I am at 260) I get a tiny click once in a while on my X axis motor. Now if I set my tension over 270 then the clicking goes away. So what should I do?  Stay at the recommended tension or just go above it? Also is the clicking a bad thing.  FYI new build.
Thank you for any advise..
Questa discussione è stata modificata 6 years fa 3 tempo da Flex
Postato : 25/05/2020 3:11 pm
Flex
 Flex
(@flex)
RE: X axis belt Tension with X axis motor clicks
FYI spoke to Support. They said 275 is acceptable. I manged to get to 266 no clicking, so I stayed in rage.
Postato : 25/05/2020 4:13 pm
