Working, but.... rattling sound
Hey all -- assembled the printer in about 7 hours with only one obvious mistake (hotend wire not routed through channel before I put the fan on), have learned some of the nuances of the printer and getting good first layer adhesion (some trial and error there on Z axis adjustment), getting great quality prints in general.
However, after a few prints the X axis movement is beginning to rattle, I attached a video ( ), welcome any feedback/suggestions!
Thank you,
Tad.
Re: Working, but.... rattling sound
Check if you have same issue when moving caret by hand and with belt free from motor. The noise may come from linear bearings, in that case you should be able to notice it.
__
Best regards, Zhatkin Andrey
Thank you! I will try that after this monster 18 hour print I have going. 🙂
T.
Have you fix the issue? any actualization?
