Wont read sd card
Spiffy Wolf
(@spiffy-wolf)
Wont read sd card
Hi I am stuck and cannot get printer to recognize the sd card that came or another one I have .
Card went in 'tight' to begin.
I have restarted and flashed the firmware
I even tried printing through computer but my machine could not see path.
Loose nut behind the keyboard.
Should I reset to factory settings and flash then the wizard again ?
Tanks
Best Answer by Steve:
Spiffy,
I don't have any firsthand knowledge of this issue, however, some who have reported similar issues note that you may have success with pulling the card back slightly in the slot.  If this works, or even if it does not, your next step should probably be contacting Prusa technical support via the E-shop chat.  They are very responsive and will hopefully get you up and printing quickly.
Regards,
Steve
Napsal : 25/03/2020 12:28 am
Steve
(@steve-5)
RE: Wont read sd card
Spiffy,
Regards,
Steve
Napsal : 25/03/2020 1:38 am
1 lidem se líbí
