Why are there extra X-asis parts in the MK3S to MK3S+?
Rob Smakman
(@rob-smakman)
After receiving my upgrade, I downloaded the MK3S to MK3S+ upgrade STL files.
Within the set there's also two parts which are not mentioned in the upgrade instructions: x-end-idler and x-end-motor.
Does anybody know what the purpose is for adding these parts, or am I really missing something in the upgrade instructions.
Opublikowany : 12/06/2021 11:03 am
Baklin
(@baklin)
RE: Why are there extra X-asis parts in the MK3S to MK3S+?
These are mentioned in step 2 of the first chapter of the manual.
The MK3S+ used a different system to tension the X belt. If you want to install that too you will need to use the MK3S+ manual.
Opublikowany : 12/06/2021 8:32 pm
Rob Smakman
(@rob-smakman)
Thanks Baklin. overlooked this part.
Opublikowany : 12/06/2021 8:57 pm
