What's really in that Surface Cleaner Sachet?
AlfaXL
(@alfaxl)
It says it is Isopropyl Alcohol, but it doesn't clean very well. My first two Boaty McBenchy tests floated off the bed. Then I cleaned it with my own 99% IPA and things are now sticking. Whatever is in that sachet it smells like tequila, and seems to be as effective as you would imagine tequila to be.
Veröffentlicht : 28/04/2021 7:06 pm
Clarmrrsn
(@clarmrrsn)
RE: What's really in that Surface Cleaner Sachet?
IPA is not really that great at cleaning, only between prints when there is no grease on the bed.
Better with fairy/dawn unscented, rince with lots of hot water and dry thouroughly, preferrably on radiator or heat bed.
Once a month with acetone 100% is also very effective.
Tank you very much!
Veröffentlicht : 28/04/2021 8:45 pm
Clarmrrsn
(@clarmrrsn)
Also, the wipes are not great, not enough IPA to clean, you really need a lot to have any effect.
Tank you very much!
Veröffentlicht : 28/04/2021 8:46 pm
A 5cm puddle of alcohol can work if your fingers are dry and not oily or loaded with hand lotion, and you use a fresh folded paper towel or a large microfiber cloth that doesn't melt when alcohol hits it. Otherwise, soap and water is best for the smooth PEI sheet.
Veröffentlicht : 29/04/2021 9:13 am
