What’s causing this end of print issue?
ryan.s59
(@ryan-s59)
This is the second time in a row this has happened at nearly the same spot on my MK3s. Everything else seems spot on! Good first layer and everything. I did notice this spool of PLA was rated at 215-220 and my ending layers were set to 210. I just increased this and hope for the best. Any ideas? I notice the print is no longer stuck to the bed after this issue. I Successfully printed the tall vase on the Prusa memory card, but with different filament..
Veröffentlicht : 01/03/2019 1:41 pm
lee.g
(@lee-g)
Re: What’s causing this end of print issue?
Your first layer is not great.
If you get your first layer dialled in perfect and the bed is clean then I would try to print again.
There may be other problems but if just looks like it has detached from the bed.
Veröffentlicht : 01/03/2019 2:57 pm
vintagepc
(@vintagepc)
Mitglied
This. Had the exact same effect happen when a similar sized part detached on my bed.
Make sure the bed is spotless (use dish soap and warm water), adjust live Z, and if you still have issues use a brim.
Veröffentlicht : 01/03/2019 3:05 pm
ryan.s59
(@ryan-s59)
Thanks all! I thought my first layer looked good... should it be more smooth? Less ridges?
Veröffentlicht : 02/03/2019 1:04 am
vintagepc
(@vintagepc)
Mitglied
Yes, you need to smush the plastic more. There's still too much gap between each trace from the nozzle.
Veröffentlicht : 02/03/2019 1:19 am
And as a last resort - you can add a brim of 8 mm to help keep the part tacked down.
Veröffentlicht : 02/03/2019 5:26 am
Mustrum Ridcully
(@mustrum-ridcully-2)
the best prep for your bed is to wash it with warm water and dawn dish soap (in the UK use Fairy liquid) by using a wad of clean kitchen paper towel dampen with warm water and put a dollop of Dawn on the pad and scrub (i do it twice at 90 deg to each other holding the plate by the edge as it is a phonograph record rinse under running water and dry with clean paper towel keep touching only by the edge... I do this every other day of printing with both kinds of plate.
then set your live z with this method https://shop.prusa3d.com/forum/assembly-and-first-prints-troubleshooting-f62/life-adjust-z-my-way-t2981.html it is far better than the zig zag method in the firmware
Veröffentlicht : 02/03/2019 11:29 pm
