[Résolu] What Is Wetting My Bed?
Taken4Granted
(@taken4granted)
Hi everybody,
Alright so I just got my printer up and running. I have done a few prints. I noticed after every print there are these dots all over my print bed that looks like it's been sprayed slightly then evaporated. Has any one else encountered this?
I wipe down the bed thoroughly in between each print with 99% isopropyl alcohol.
I didn't care at first but I also recently started having issues with slight warping/ things getting knocked off the bed so now I am questioning it. I don't think that is related (but maybe it is?). (I've got cold drafts in my room, building an enclosure now).
Mk3s+ kit.
PLA.
Standard PLA settings.
Theories, ideas, or call for concern?
Thanks
Best Answer by JoanTabb:
Could this be the shipping fluid, that Misumi admit to putting in Most of their bearings...
there is a lot of difference of opinion over lubrication of the bearings
contrary to the assembly manual, Misumi advise that the bearings should be washed in IPA, and lubed with suitable Lithium grease...
there have been a number of reports of oil contamination, on the build plates.
I Would suggest that you consider washing the build plate with hot water and dish soap, then rinse with hot water, and dry immediately
then I suggest that you wipe the rods off with IPA and a cloth, to get as much oil off them as possible, then I suggest that you lubricate the bearings with grease as Prusa recommend
https://help.prusa3d.com/en/guide/printer-maintenance-tips_23200
Publié : 10/03/2021 11:26 pm
RE: What Is Wetting My Bed?
Publié : 10/03/2021 11:45 pm
Taken4Granted
(@taken4granted)
@joantabb
That is a great thought! I will look into it and re-post when I get the chance.
Thanks for feedback.
Publié : 10/03/2021 11:55 pm
Dan Rogers
(@dan-rogers)
I used to get those until my bearings got broken in.
Publié : 12/03/2021 7:54 pm
@dan-rogers
You might be wise to grease your rods too!
Publié : 13/03/2021 4:29 am
Clarmrrsn
(@clarmrrsn)
Posted by: @joantabb
I will be getting my MK3 next week, and was just going to wipe the bearings down with a lint free cloth inside and out, then superlube (400g should be just about enough 😁) My initial opinion was soaking is a step too far, however after seeing this I think I will certainly soak the bearings in IPA, then a good dry off and finally a good layer if superlube.
Have installed hundreds of bearings in my career, and never saw so much fluid come out of any, must be specific to Misumi.
That is an awful mess, and certainly that amount of oil flying around a 3d printer is not really what you want.
I wonder if Prusa could ammend the build manual to include soaking in IPA then greasing the bearings and rods.
Thanks for the info, very helpful.
Ce message a été modifié il y a 5 years par Clarmrrsn
Tank you very much!
Publié : 13/03/2021 10:10 am
Taken4Granted
(@taken4granted)
Alright folks, I'm back. So I went back and wiped off the rods with IPA and then put some super lube on the rods. And after running it yesterday for 10hrs no drops!
Thanks Joan for the advice. I think you were spot on!
Publié : 13/03/2021 2:20 pm
@taken4granted
Excellent News.
I have been talking to Prusa about updating the instructions. there are different comments in different guides!
a Bit of Synergy would be good
Publié : 13/03/2021 3:49 pm
1 personnes ont aimé
