What is this clicking sound from Y-Stepper / Y axis???
Christizzz
(@christizzz)
Hello,
it is still printing and there is an annoying clickign sound that pops out here and then when the Y axis changes direction:
https://drive.google.com/file/d/1xD7I-o4SiR6Ahz0WOceCHyQ01L9iYXeQ/view?usp=sharing
https://drive.google.com/file/d/12FPhY3ivxDS81ytyY9wN6_ZsK4bydhSQ/view?usp=sharing
assembled the printer on thurday ran into:
Bad LCD with a dark line ---> got replaced
Warped BED ----> replacement on the way
Trapezoidal nuts with bad tolerance ---> replacement on the way
Support was awesome... i discover new sounds and problesm every day... 🙁
Posted : 04/09/2018 12:58 am
Bigdogbro1
(@bigdogbro1)
Re: What is this clicking sound from Y-Stepper / Y axis???
I have two MK3 kits that have the same thing happening. From my investigation it seems to not be a motor mechanical issue because it is not repeatable when doing a full travel HOME movement. It seems to occur only during certain printing speeds around 50mm/sec. I don't think it is a belt tooth to pulley tooth mismatch because it doesn't do it all the time or in time with the pulley rotation. My belts are tightened midrange spec 275+/- and no debris in the belt or pulley. I think it's something to do with the stepper motor driver.
Try it in STEALTH MODE and see if it clicks then.
MK3 Kit, Designed, built 4x4 CNC Plasma Cutting Table, Motorcycles Bigdogbro's Adventures
http://www.youtube.com/channel/UC5djrxBeeOKB9_6rHnn6G8A
Posted : 05/09/2018 3:04 pm
Christizzz
(@christizzz)
So...i reduced the tensioning of the Y belt... it seems to be better... but as you said it was not constant... it was doing it a t certain moves/speeds.
Posted : 07/09/2018 1:50 pm
