Weird printing issue
hodrob
(@hodrob)
Any tips, what is causing this?
I printed a lot of things before. But I had Y-axis linear bearing problems, so I switched them a few days ago. I also had to disassemble a bit the extruder, but not completely.
The Y-axis seems smooth enough, I can easily move it.
Respondido : 03/03/2019 12:54 pm
vintagepc
(@vintagepc)
Miembro
Re: Weird printing issue
I suspect you may be suffering from this:
https://github.com/prusa3d/Prusa-Firmware/issues/1522
Rumor has it disabling your filament sensor may help.
Respondido : 03/03/2019 1:51 pm
hodrob
(@hodrob)
Holy....!!! You may be right. I totally forgot about that. I updated the firmware yesterday late night... It seems, that one beer was enough to clear my memories. 🙂
Let me try to downgrade then. Thanks!
Respondido : 03/03/2019 2:23 pm
hodrob
(@hodrob)
Ahh, no... I WANTED to upgrade, but somehow I could make the octoprint firmware upgrade working... And I was lazy to go upstairs for a USB cable... So I'm still on 3.5.1. I remember now.
Edit: Ohh, I see, this is not a 3.5.2 problem. He wrote, he had the problem with 3.5.1 also.
So if it is a SW bug, how can I print this stuff? (let me check the related issues...)
Respondido : 03/03/2019 2:28 pm
vintagepc
(@vintagepc)
Miembro
Have you tried disabling the filament sensor? There's some suspicion this is the reason for the problem.
Respondido : 03/03/2019 2:45 pm
hodrob
(@hodrob)
I will do that right now. I'm just re-wiring my power supply. (Cables are too short since I put a granite under my printer.)
Respondido : 03/03/2019 3:16 pm
hodrob
(@hodrob)
It seems, it did the trick! Thanks! With disabled filament sensor, I was able to print this.
Respondido : 04/03/2019 8:47 am
vintagepc
(@vintagepc)
Miembro
I switched to an indirect sensor mod for the R4 extruder parts with the old sensor; I've no longer had that issue either. 🙂
Respondido : 04/03/2019 1:33 pm
hodrob
(@hodrob)
Indirect sensor? I assume, that is similar design to the mk3s. I ordered it a week ago or so.
This one?
https://www.thingiverse.com/thing:3223513
Respondido : 04/03/2019 3:00 pm
vintagepc
(@vintagepc)
Miembro
This one?
https://www.thingiverse.com/thing:3431164 actually. No sensor change required 🙂
Respondido : 04/03/2019 4:34 pm
hodrob
(@hodrob)
Thanks! I'll wait for the original upgrade - as I already payed it :). We'll see, how it goes. If still failing, I'll have a backup plan then.
Respondido : 04/03/2019 11:43 pm
