Weird first layer issues
Skint007
(@skint007)
I'm not sure what's causing this issue, I've done about 15 first layer calibrations and no matter how close I get it, the lines won't come together. I then tried doing the calibration with the 75x75 first layer test. Usually when I get the nozzle to close to the bed it will start to ball up and stick to the nozzle.
The 75x75 test prints a very weird pattern, any ideas what could be wrong here?
Best Answer by Peter M:
Your first layer is to high. You can see between the lines of filament.
First layer should be pushed down on the bed, and not be nice round laying on top of the bed.
To get first layer good: (So it sticks good, and you do not get a ball of filament sticking to the nozzle).
1. Clean bed,  with dish soap every few prints, between the dish soap use alcohol. Always dish soap is also possible.(on pei sheet).
2. First layer should be perfect, to get maximum sticking. Look on youtube for movies on how to do this.
Big flat models and models with small footprint to the bed, use glue stick, and search/test for good glue stick.
For these models also use a big brim, attach to the model.
Postato : 20/06/2020 4:20 am
RE: Weird first layer issues
If you have not already done so, try using Jeff Jordan's "Life Adjust" procedure for calibrating your Live-Z setting. It is much easier to use and understand than the on-board routine and much easier to make mid-print adjustments accurately with. In general, start high (less negative) and work lower (more negative) in large increments (e.g. 0.1mm) until the filament starts to stick on its own. When you've got your Live-Z setting adjusted properly, you should be able to gently rub the extruded lines on the PEI surface without dislodging them.  Then start lowering (more negative) the level until there are no gaps between layers. You should not be able to peel the lines apart after printing, but the top should be regular.
Postato : 20/06/2020 3:42 pm
Peter M
(@peter-m)
Postato : 20/06/2020 8:38 pm
Skint007
(@skint007)
Posted by: @peter-m26
Yeah it being to high was an understatement lol. I went from -0.820 to -1.220 as my final offset... Might play around with it some more but looks like it did before I did the upgrade to the mk3s 🙂 thank you guys!
Postato : 21/06/2020 5:20 am
Peter M
(@peter-m)
Do a z calibration, if you change something on your printer.
Do a first layer check.
Check every print the first layer, so you do not damage your bed, and that the layer is perfect so the print will be good(stick good), and you do not get a big ball of filament on the nozzle sticking.
Postato : 21/06/2020 6:16 am
Skint007
(@skint007)
Yeah that was the first thing I did, a full recalibration after doing the upgrade. I noticed this new smooth sheet isn't as sticky as my old one.
Currently doing my first print in 2 months and it's looking perfect 😎
Postato : 21/06/2020 6:27 am
Heather Mac Lellan
(@heather-mac-lellan)
Utenti
Hi, Did you ever get this figured out? I'm having the same problem with the second hand printer that I just bought.
Postato : 21/08/2025 7:42 pm
