wavey lines all around print
Kris
 Kris
(@kris-5)
Hello,
My printer is consistently giving this wavey pattern all around any model it's printing at the moment. I can't really tell what's wrong however. I cleaned the nozzle, I used different filaments, I haven't swapped the nozzle just yet though.
I recalibrated the whole thing, checked the belts and if the bearings and rods were maybe not maintained in a while, but they had a touch-up about 3 or 4 weeks ago.
The printer's running 6.2.6+8948, stock everything else, 0.4mm nozzle etcetera. This benchy was made without Input Shaper.
Does anyone have any thoughts what I should have a look into?
Veröffentlicht : 07/10/2025 11:43 am
Kris
 Kris
(@kris-5)
RE: wavey lines all around print
I just realized I accidentally posted in the MK3 threads, but it's supposed to be in the MK4 threads.
Veröffentlicht : 07/10/2025 11:47 am
I haven't seen exactly that before but my first thought is to check that you sliced for the correct filament.
Veröffentlicht : 07/10/2025 6:54 pm
Kris
 Kris
(@kris-5)
It's the same profile I use on any of my other printers and they print just fine using the same filament though.
Veröffentlicht : 08/10/2025 5:58 am
Artur5
(@artur5)
Check that the grub screws of the X and/or Y steppers aren't a bit loose.
Veröffentlicht : 08/10/2025 1:50 pm
Kris
 Kris
(@kris-5)
turns out the nozzle was just messy, replacing it fixed pretty much all issues.
Veröffentlicht : 25/11/2025 4:08 pm
