Warping on first print
EHB
 EHB
(@ehb)
I assembled the Prusa MK3S+ and all tests passed successfully on the first try.  I have had experience with 3D printers before including the Lulzbot Mini.
I LOVE the Prusa, but am having a problem getting the first test print to successfully finish.  I have tried multiple times, and I always seem to experience warping or complete separation from the bed after the first few layers - picture below of the MOST successful version so far (some have failed after only a few layers)
I watched the help video:
and also the Warping tips:
https://help.prusa3d.com/article/warping_2011
I have not tried using the suggested glue stick b/c I just feel like w/ everything I have read about the quality of the printer and results from other users, that really shouldn't be necessary <?>
Please let me know if there are any calibration or build steps I could try that might help. Thank you so much
Respondido : 19/03/2023 4:51 pm
Your photo is a little too fuzzy to be sure.  Please run the built in first layer 'Z' calibration and show us the result *on the print-sheet*.
Respondido : 20/03/2023 3:09 am
Robin
(@robin)
RE: Warping on first print
You do not need gluestick to print PLA on the smooth PEI. Run first layer calibration and post a picture of the result still on the print bed.
Respondido : 20/03/2023 10:21 am
EHB
 EHB
(@ehb)
Thank you both so much for responding right away!  I still don't see anything that stands out about the first layer calibration - I really hope you do!
It looks like I can only attach one picture, so I'm trying this one.  If you need additional pictures, I have taken a bunch. I also left the print on the bed or can run any more tests you would like
Thank you again!
Respondido : 21/03/2023 11:52 pm
Crab
 Crab
(@crab)
Your first layer needs to be lower. If you see roundness and shadows it is too high.
Respondido : 22/03/2023 9:57 pm
Your first layer calibration can usefully go lower and there are suspicious smears on your print sheet; it needs to be scrupulously clean.
Respondido : 23/03/2023 12:46 am
EHB
 EHB
(@ehb)
Thank you both - currently, my setting displayed prior to
"Sheet Smooth1"
"Z Offset: -1.040mm"
I will go lower (increasing the minus Z offset)
I wipe the bed before each run with CURAD Alcohol Prep Pad 2-ply, 70% isopropyl alcohol - is that OK or should I use something else?
Something I noticed while the printer is "Heating....", it displays  "Z   5.00?"  -> is that normal?
Thank you so much!
Respondido : 23/03/2023 1:24 am
EHB
 EHB
(@ehb)
Success w/ Z at -1.112
Thank you again!!
Respondido : 23/03/2023 3:16 am
