Variation in PLA questions
Mustrum Ridcully
(@mustrum-ridcully-2)
I have mentioned that all of my 3D printing before this MK3 kit was with my Rostock Max V2.5 and on that delta printer I printed ABS only but I printed ABS from about 5 vendors and the results were remarkably similar.
on this MK3 I have so far only printed two different PLAs the spool of Prusa silver that came in the kit and a NOS spool of Hatchbox very glossy PLA produced in 2015 I have had excellent results with both and the Blue is making great structural parts
the parts arr fine except for some print in place models like this Fidget cube
https://www.thingiverse.com/thing:2848678
in Prusa PLA it prints just fine and on can fidget away after flexing each joint a few times to free it up but when printed with the same Pretty PLA v3 slice from Slic3r-pr (same Gcode file) with this very glossy Hatchbox it creates a solid block of plastic and using wrenches will free up some of the joints/hinges others will snap the hinge attachments in a few areas.
is this linked to the very glossy almost wet effect of this Hatchbox PLA? Doubtless as I gain more experience with PLA I will learn to modify the Slic3r-pr settings to each individual brand/type of PLA
Napsal : 28/10/2018 4:31 pm
