Uneven outside wall
Ben Laurie
(@ben-laurie)
Uneven outside wall
See image - the unevenness corresponds to the level where it changes from being solid base to having a think wall.
Its worse on some sides than others.
Any hints on how to stop this?
Napsal : 16/09/2018 1:58 pm
Tsuris1321
(@tsuris1321)
Re: Uneven outside wall
Bumping for similar issue in case someone has an answer
Napsal : 26/09/2018 10:36 pm
Hi Ben, Jacob,
could you post a sample stl and gcode of a simple model that displays this artefact please?
if you zip the files, you can attach the zipfile... regards Joan
Napsal : 27/09/2018 12:03 am
Tsuris1321
(@tsuris1321)
Will do, as soon as I can get back to my home computer; but that won't be for a few hours yet.
Napsal : 27/09/2018 12:09 am
Pathogen
(@pathogen)
I often also see stuff done in the inside get expressed out through the outer walls as well. Infill will do funny things to the outside surface as well. Thankfully we will have Joan on the case so this will get solved! :ugeek:
Napsal : 27/09/2018 1:56 am
Tsuris1321
(@tsuris1321)
Here is the zip folder with the STL file and sliced g-code for my print. Also a picture of my own from my print with the issue.
Napsal : 27/09/2018 3:19 am
Tsuris1321
(@tsuris1321)
print with issue
