try to print using Simplify3d software
sonra
(@sonra)
Hi
I try my new MK3s printer and  I pass the calibration phase . because I  got  used to S3D  with my other printer I try to use it also my   new machine . Installed  a profile   that i download from " https://prusa3d.dozuki.com/Guide/How+to+import+profiles+to+Simplify3D+4.x+(Windows+&+macOS)/1423?lang=en&permalink=1 " and give it a try . the result was a little surprise because the part  was printer shorter in  X   then the part printed in other   printer . I use the  PLA 0.1 -Detail profile  because the part is  small . Any idea ?
regards Doron
Opublikowany : 13/02/2021 10:08 pm
RE: try to print using Simplify3d software
I have just compared prints from S3D and Prusa Slicer and I don't see any dimensional difference. my model long axis was along the X axis, my model narrow axis was along the Y axis, and the intermediate axis was Z!
Opublikowany : 13/02/2021 11:30 pm
sonra
(@sonra)
Thanks Will try again
regards Doron
Opublikowany : 15/02/2021 2:14 pm
sonra
(@sonra)
Simplify 3D profiles often embed some machine parameters in the start gcode. Open a S3D generated gcode file in a text editor and look for a series of M20X lines near the top. Compare these to the values entered in Machine settings in PrusaSlicer.
Opublikowany : 15/02/2021 2:45 pm
sonra
(@sonra)
Maybe i did  not  describe the problem clearly  , the part i design  using OpenScad software  . print it  in my old printer  using S3D    and then printed it using   the MK3  printer with  both S3d  and  Pronterface   and the part was shorter in X both cases . Any idea ?
Regards Doron
Opublikowany : 16/02/2021 5:57 pm
@sonra
are you saying the when designed the part was say 100mm long, but both Prusa slicer and S3D print it at say 99mm long?
can you save the Prusa Slicer version, as a project file (.3mf) then zip compress the file and attach the compressed zip file to the next post?
Opublikowany : 16/02/2021 6:16 pm
I think what @sonra is saying is that the part was sliced in S3D, and the gcode printed to the Mk3 via Pronterface, and the result is 99mm versus the same printed to another printer at 100mm. My suggestion to compare the M20x hardware settings stands.
Opublikowany : 16/02/2021 7:20 pm
sonra
(@sonra)
Hi the part X=34mm  in design  After print it is 32 mm
Opublikowany : 16/02/2021 7:27 pm
sonra
(@sonra)
for some reason I get a message from the forum that I can  not attach zip files
Opublikowany : 16/02/2021 7:28 pm
Hi Sonra,
I have Private Messaged you.
Opublikowany : 16/02/2021 7:47 pm
Hi Sonra
when I sliced and printed your file, it came out almost exactly 34mm
Note the frame is supported in mid air, in the picture so there must be a little clamping effect. in reality this is probably 33.99mm +- tollerance on the vernier calliper...
if yous a lot different?
the dimensions in Prusa Slicer are coming out at 34 x29 x 3mm
Opublikowany : 17/02/2021 2:50 pm
sonra
(@sonra)
hi
Can you send  to me your setting for the  S3d  software  .Maybe some setting cause the problem
Opublikowany : 17/02/2021 3:33 pm
Sorry I printed in Prusa Slicer...
I will give S3D a try
Opublikowany : 17/02/2021 9:21 pm
Here you are Sonra,
this one came out 34.27 x 29.22 x 3
and the FFF file is Prusa Research Original Prusa i3 MK3 (modified)
Opublikowany : 17/02/2021 9:58 pm
sonra
(@sonra)
Hi
i try your profile but it does not help. I attach  picture  the left part  is from my old printer the right is from the  Prusa  as you can see there is  shift in some layers  S o  i suppose some thing is nor set OK in the printer
Opublikowany : 18/02/2021 4:07 pm
@sonra
It looks that way Sonra
Opublikowany : 18/02/2021 5:37 pm
sonra
(@sonra)
RE: try to print using Simplify3d software ( problem solved )
Hi
Found the problem  the X  motor pulley screws were not tighten
Thanks for help Doron
Opublikowany : 19/02/2021 12:21 pm
@sonra
Small screw, big cause. I would also take the opportunity to check the other pulleys and the belt tensions. There is a small and simple tool for calibrating the belt tension: https://www.prusaprinters.org/prints/46639-tension-meter-for-the-gt2-belts-of-i3-mk3s-or-prus
happy printing!
Opublikowany : 19/02/2021 12:34 pm
sonra
(@sonra)
thanks will try the tool
Opublikowany : 19/02/2021 1:31 pm
