try to print using Simplify3d software
Hi
I try my new MK3s printer and I pass the calibration phase . because I got used to S3D with my other printer I try to use it also my new machine . Installed a profile that i download from " https://prusa3d.dozuki.com/Guide/How+to+import+profiles+to+Simplify3D+4.x+(Windows+&+macOS)/1423?lang=en&permalink=1 " and give it a try . the result was a little surprise because the part was printer shorter in X then the part printed in other printer . I use the PLA 0.1 -Detail profile because the part is small . Any idea ?
regards Doron
RE: try to print using Simplify3d software
I have just compared prints from S3D and Prusa Slicer and I don't see any dimensional difference. my model long axis was along the X axis, my model narrow axis was along the Y axis, and the intermediate axis was Z!
Thanks Will try again
regards Doron
Simplify 3D profiles often embed some machine parameters in the start gcode. Open a S3D generated gcode file in a text editor and look for a series of M20X lines near the top. Compare these to the values entered in Machine settings in PrusaSlicer.
Maybe i did not describe the problem clearly , the part i design using OpenScad software . print it in my old printer using S3D and then printed it using the MK3 printer with both S3d and Pronterface and the part was shorter in X both cases . Any idea ?
Regards Doron
@sonra
are you saying the when designed the part was say 100mm long, but both Prusa slicer and S3D print it at say 99mm long?
can you save the Prusa Slicer version, as a project file (.3mf) then zip compress the file and attach the compressed zip file to the next post?
I think what @sonra is saying is that the part was sliced in S3D, and the gcode printed to the Mk3 via Pronterface, and the result is 99mm versus the same printed to another printer at 100mm. My suggestion to compare the M20x hardware settings stands.
Hi the part X=34mm in design After print it is 32 mm
for some reason I get a message from the forum that I can not attach zip files
Hi Sonra,
I have Private Messaged you.
Hi Sonra
when I sliced and printed your file, it came out almost exactly 34mm
Note the frame is supported in mid air, in the picture so there must be a little clamping effect. in reality this is probably 33.99mm +- tollerance on the vernier calliper...
if yous a lot different?
the dimensions in Prusa Slicer are coming out at 34 x29 x 3mm
hi
Can you send to me your setting for the S3d software .Maybe some setting cause the problem
Sorry I printed in Prusa Slicer...
I will give S3D a try
Here you are Sonra,
this one came out 34.27 x 29.22 x 3
and the FFF file is Prusa Research Original Prusa i3 MK3 (modified)
Hi
i try your profile but it does not help. I attach picture the left part is from my old printer the right is from the Prusa as you can see there is shift in some layers S o i suppose some thing is nor set OK in the printer
@sonra
It looks that way Sonra
RE: try to print using Simplify3d software ( problem solved )
Hi
Found the problem the X motor pulley screws were not tighten
Thanks for help Doron
@sonra
Small screw, big cause. I would also take the opportunity to check the other pulleys and the belt tensions. There is a small and simple tool for calibrating the belt tension: https://www.prusaprinters.org/prints/46639-tension-meter-for-the-gt2-belts-of-i3-mk3s-or-prus
happy printing!
thanks will try the tool
