Tree Frog - First Print Perfect but Second time had issues
Kawibunga
(@kawibunga)
Hi There!
First post, first 3D printer but having fun. Mechanical Engineering from Calgary AB Canada......... Anyhoo, I picked up a kit and assembled it and started doing the models that came on the SD card to get a feel for things before I started playing with slicer and using my own models. I was blow away with how well things were printing. Then some prints stated to get "stringy' - so I went back and reprinted the Tree Frog. Note I've changed zero settings.
Postato : 18/04/2022 5:18 pm
Kawibunga
(@kawibunga)
RE: Tree Frog - First Print Perfect but Second time had issues
Note the only thing that was different is the room temperature, it was about 21°C in the room for the good print, and about 18°C in the room for the second bad print. That is the only change. And the filament is the standard PLA that ships with the kit. Thanks for any insight! Looking forward to learning and making!
Postato : 18/04/2022 5:20 pm
