TMC DRIVER OVERTEMP when rotating knob while SD card is inserted
James
(@james-12)
I assembled my printer and the self test and calibration went fine. Then I put in the SD card and rotated the knob and got that error. I reset the printer and the same thing happened. If I take out the SD card and go through the different menus, then I don't get the error. If I put the SD card back in and rotate the knob, I get the error. But I found that if I rotate the knob very slowly, the error won't come up, and I was able to print an object which printed fine.
What would be causing that?
Thank you 🙂
Posted : 11/02/2021 7:38 pm
Jack
 Jack
(@jack-8)
RE: TMC DRIVER OVERTEMP when rotating knob while SD card is inserted
Same here.
I've posted TMC DRIVER OVERTEMP problem here :
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/tmc-drive-overtemp-durin-calibration-process/#post-341347
Prusa support send me another EINSY RAMBO card. I've reassembled the printer this week and the problem remains. Only yesterday I oberved thant TMC DRIVER OVERTEMP comes up when SD card is inserted and knob rotated, I wasn't aware about thar in previous process.
If this is a more wide observed problem I hope Prusa will find a solution quckly.
My drivers version is 3.9.2 (not yet updated after receiving the board)
Posted : 12/02/2021 8:27 am
Jack
 Jack
(@jack-8)
Update after an exchange with Prusa Support :
I manged to calibrate the printer. Printing from SD card is currently impossible but it can be done through Pronterface ( https://www.pronterface.com/)
Printing was correctly done. No problem with the result. That seems to validate the printer assembly. And it seems that SD card reader / screen has some issues 🙁
Posted : 12/02/2021 11:39 am
James
(@james-12)
I also was able to print perfectly fine through pronterface. And got in touch with support. They sent me a new LCD/SD unit but I still have the same issue as my original post with the new one.
Posted : 26/02/2021 6:23 pm
Clarmrrsn
(@clarmrrsn)
Quick question,  sounds unrelated, but can't see this mentioned in either thread.
Have you tried reformatting the SD Card, or tried a different card, certain SD cards have been known to be temperamental, by the description of the fault probably nothing to do with it, but thought worth a mention.
Tank you very much!
Posted : 26/02/2021 10:49 pm
James
(@james-12)
Yeah I did. Sorry, I probably should've added more information to my post.
I've used 4 different SD Cards. My firmware is the latest version. I've checked the idle temperatures and running temperatures. And I double checked/rewired everything.
When I contacted support I showed them the issue through a video and how different SD cards gave the same error. And then they sent me the new LCD/SD unit.
Posted : 26/02/2021 11:20 pm
Jack
 Jack
(@jack-8)
Hi James,
I dont know how but before I received a new screen the problem we're talking about just vanished. Why ? I do not know. I'm now at more than 100h of printing time and I can use the knob with no issues. It vanished during a print without any action from me.
One curious thing : When the problem was still there I observed that there was 1 postion (3 o'clock) that was making the printer (with inserted SD card) booting directly into  OVERTEMP error. If I managed to stay out of this position when manipulating the knob : there were no problem.
Posted : 27/02/2021 6:19 am
Clarmrrsn
(@clarmrrsn)
I had a quick look at this error.
From my recent reads of the install manual waiting on my MK3 to arrive I seem to remember the flex ribbon between pcb and lcd  is inserted inside the Alu extrusion to keep the cabling tidy, could this have damaged the insulation resulting in a short from the flex cable to the alu frame?
Also a tight cable tie around the cables could cause a short between cables, I would cut the zip ties off if tight and re-do them loose, also check your cable runs, inspect your cables, make sure there is nothing shorting anywhere, a short can come from the tiniest of breaks in cable insulation, believe me they can be very challenging to find as I work on huge 3 phase production printers with massive looms, have pulled my hair out with many a short which was a tiny hole in the insulation.
The manual does mention a short circuit as a possible cause of this error
https://help.prusa3d.com/en/article/tmc-driver-overtemp_1813
Tank you very much!
Posted : 27/02/2021 10:29 am
