[Resuelto] Stripped Screw and Stripped Screw hole on extruder
Rocket printer
(@rocket-printer)
Hi Everyone, I was repairing my Mk3s+ when I accidentally overtightened a screw on the extruder(M3x40). I have managed to get a hex key in and turn it with the screw, but the screw won't come back. It's just spinning in the threads. I have gotten it about 5mm out but not any farther. Any Ideas?
Thanks,
Rocket printer
Respondido : 01/01/2024 6:56 pm
JimB
 JimB
(@jimb)
RE: Stripped Screw and Stripped Screw hole on extruder
Option 1) grab it with a pliers and turn while pulling.   2) get a small screwdriver under the head to apply outward force while using the hex key to loosen it further.  3) maybe use something like https://www.amazon.com/dp/B07YXXZDT9
Respondido : 01/01/2024 8:23 pm
1 les gusta
Rocket printer
(@rocket-printer)
Thanks for the suggestions. I already tried options 1 and 2, to no effect, so I will try option 3. I exposed the thread on another part but it is not turning even with pliers. I'm not sure if it's stuck or something.
Respondido : 01/01/2024 8:34 pm
Rocket printer
(@rocket-printer)
I have tried all methods so this leaves cutting the visible thread with a Dremel and pulling the rest out.
Respondido : 02/01/2024 8:49 pm
