Stringy First Prints
christopher.a16
(@christopher-a16)
Hello Everyone,
After assemble, the batarang, whistle and Prusa logo completed successfully. Attempting to print a benchy has failed twice with the below results. Does this require reseting the Z axis (a first layer problem) or some other issue? Can someone suggest a fix?
thanks!
Postato : 21/11/2018 3:57 pm
fourmizator
(@fourmizator)
Re: Stringy First Prints
Were you able to see when the problem occurs ? It could help finding the root cause
Try looking it while printing ?
Postato : 21/11/2018 4:46 pm
RH_Dreambox
(@rh_dreambox)
I can not see on your pictures how the first layer looks, so it's not possible to determine if you need to correct the Z level.
But what you should do before continuing the troubleshooting is to wash the bed with detergent and water.
A dirty bed (finger prints) is one of the most common causes of printing problems.
Postato : 21/11/2018 5:22 pm
Mustrum Ridcully
(@mustrum-ridcully-2)
follow this thread after yo wash your build plate with washing up liquid (not soap) like Dawn in North America or Fairy Liquid in the UK
https://shop.prusa3d.com/forum/assembly-and-first-prints-troubleshooting-f62/life-adjust-z-my-way-t2981.html
Postato : 21/11/2018 10:47 pm
christopher.a16
(@christopher-a16)
Thanks everyone. I adjusted the z calibration and was able to successfully print benchy. I'm going to start another thread for feedback on the print.
Postato : 22/11/2018 2:34 pm
