Stringing Since First Print
Spencer Weaver
(@spencer-weaver)
Utenti
Using PLA, I've tried 3 different spools from two different manufacturers, all in different colors.
I have been printing temp towers to try and get the stringing under control, to no avail.
I have tried a few different retraction settings, even some extreme ones (I don't remember exact settings).
Please see images. Even 180C is showing some stringing, and I am under the impression I should be able to print at 200-215C without significant issues.
I am not sure what to do, this is my first 3D printer. Temperature/humidity of printing environment included in pics.
Included pic of my extruder - do these wires need adjusted? I am thinking yes, but again, newbie.
TIA
Postato : 02/04/2024 7:43 pm
That looks like wet filament.  Try drying it (look up threads here) and come back if problems persist.
Postato : 02/04/2024 11:16 pm
Spencer Weaver
(@spencer-weaver)
Utenti
RE: Stringing Since First Print
That was my thinking, but using 3 different brand new filaments led me to believe that may not be the case. I'll give drying it out a go. Thanks!
Postato : 02/04/2024 11:51 pm
JA
 JA
(@ja-2)
Any recommendations for a filament dryer?
Thanks,
Jim
Postato : 03/04/2024 11:03 pm
Robin
(@robin)
I am using one from PrintDry for some time now and since they got new models out you might get the old one for a good price...
Postato : 07/04/2024 1:33 pm
Many of us use food dehydrators - cheap kitchen apparatus lightly modified to hold spools of filament - you can make workshop snacks as a sideline.
You have a choice of cutting out the centre of the food trays or printing a new extra-deep filament-drying tray.
Postato : 07/04/2024 4:18 pm
Robin
(@robin)
I wonder if I can make snacks in the printDry…
Postato : 07/04/2024 7:00 pm
JA
 JA
(@ja-2)
All,
Thanks for your help on this.  I bought a dryer.  Initially the spool was at 57%, I dried the spool to 39% and NO STRINGS!  You all are awesome!!
Thanks again!
Jim
Postato : 07/04/2024 10:41 pm
JimB
 JimB
(@jimb)
There are food dehydrators you can get that don't needed any modification and have room enough for several 1kg spools.  I have one with shelves that slide in/out from the front.  Just remove all the shelves (or all but one) and you have a nice large space for spools.
Postato : 08/04/2024 12:24 pm
Spencer Weaver
(@spencer-weaver)
Utenti
i dried the filament for 4 hours at 40C. Much improved. This is 190C print temp. Do you think it's worth a second drying session, or maybe mess with retraction at this point? I'm leaning another drying sesh.
Postato : 11/04/2024 6:46 pm
Keep drying.
Postato : 11/04/2024 10:48 pm
Robin
(@robin)
What diem said. And crank up the temp (when drying). Do not mess with retraction parameters!!
Postato : 12/04/2024 6:49 am
brianjordan
(@brianjordan-2)
Posted by: @spencer-weaver
TIA
Flashforge finder -> Flashforge Creator Pro -> Prusa MK3S -> Prusa MK4S ->???
Postato : 12/04/2024 2:35 pm
brianjordan
(@brianjordan-2)
Apologies, I started a reply which hasn't posted but reposted the original in error.
Postato : 12/04/2024 11:12 pm
