Strange under-extrusion
Robert Górski
(@robert-gorski)
Hi all,
Just bought and assembled my first MK3s+ just week ago. Can you take a look at this print?
There is a problem with it, and I cannot find similar pictures on the web.  The problem happens usually on one side of the print.
I checked belts tension, X is 247, Y is 258. The material is FormFutura PLA, sliced with Prusa Slicer, layer height 0.15 mm.
I will appreciate any advice...
Print issue
Napsal : 10/03/2023 6:06 pm
Tim Weston
(@tim-weston)
RE: Strange under-extrusion
The picture does not give us much to go on...can you post the zipped .3mf file for the project please?
Cheers,
Tim
Napsal : 10/03/2023 8:18 pm
Robert Górski
(@robert-gorski)
*.3mf are project files, right? I don't create them yet. I own three Ultimakers 2, but they are few years old now, so I want to give a chance to the Prusa MKS3+.
So, I just import STL in prusa slicer, and go with gcode.  Anyway, the situation got better when I lower the hot end temperature from 215 to 200 degrees.
I guess that is the lower limit for PLA, right? At least, that's what FormFutura PLA producer claims.
Napsal : 12/03/2023 8:27 pm
It looks like your filament is damp, drying it should improve matters.
The belt tension figure is a measure of the resistance felt by the stepper when moving the axis. On a correctly set up machine this does equate, roughly, to belt tension.
But other things can affect mechanical resistance.
Make your next print this:
https://www.prusaprinters.org/prints/46639-tension-meter-for-the-gt2-belts-of-i3-mk3s-or-prus
It MUST be printed in Prusament PETG or the spring tension will be wrong.
Let us know how you get on.
Napsal : 12/03/2023 11:43 pm
