Step in layers FAQ
Ric
 Ric
(@ric)
Step in layers FAQ
I have some small steps in my first print. When I looked at the FAQ for troubleshooting, the adjustments recommended seemed backwards -
Check the tension of your belts
Check your belt-tension. If you have an MK3 or MK3S, check the Belt Status numbers via LCD menu -> Support -> Belt Status. The values should not be under 240 and above 300, but there is no single ideal value. The number does not represent any quantity.
If your value is under (or close to) 240, you need to loosen the belt If your value over (or close to) 300, you need to tighten the belt The values are updated every time you run the Selftest or run the belt test in LCD menu -> Calibration -> Belt test.
Is this correct? If belt is under value then loosen? If belt is over then tighten?
Opublikowany : 02/01/2022 12:38 am
