Spring stuck on a busted screw
thesilesian
(@thesilesian)
I have a stripped out nut stuck on the screw for the extruder idler. It doesn't look like there's a spare spring in the box. I've tried heating the screw and nut to get it off, no luck.
What's the best move here? Should I be asking for a new part, or can I use any old spring of a matching size from a hardware store?
here's the screw
This topic was modified 6 years temu by thesilesian
Opublikowany : 20/05/2020 5:14 pm
RE: Spring stuck on a busted screw
Hacksaw the nut on both sides and break the nut off the last little bit, with pliers
or hacksaw the the screw in half, and recover the spring,
or break the screw
Opublikowany : 20/05/2020 5:52 pm
