Some problem encountered Z- leveling enforced
illy
 illy
(@illy)
Hello,
I have a problem with my MK3 printer. I'm trying to print a file as usual when the printer does the 7 point on the leveling bed there is an error- "Some problem encountered Z- leveling enforced" when I click ok its starts over and the problem is showing up again.
check out the video link below
here. https://wetransfer.com/downloads/89153f63eba0287823cf45f9305a62e520220223101750/256217
Thank you very much for your help
Opublikowany : 23/02/2022 10:30 am
jwvaughn
(@jwvaughn-2)
RE: Some problem encountered Z- leveling enforced
Sorry, I don't download files so I did not watch the video.
However, if leveling has been working and then goes wacky, look for bits of material on the backside of the build plate and on the heating plate. With one exception, that has always been the source of the problem for me.  The single exception was I put the build plate on carelessly and it was on top of one of the alignment pegs at the back.
jwv
Opublikowany : 24/02/2022 3:13 am
2 ludzie polubili
Matthew D
(@matthew-d-2)
If you do the full calibration wizard does the printer pass the xy test that looks at the four corner landmarks? If you really want to get technical you can download Pronterface on your laptop and plug into the printer then run a G80 and G81 command to see what plate heights the PINDA is reading.
Opublikowany : 26/02/2022 6:20 pm
