Smooth first print problem
I've been having trouble getting a smooth first later.
When the print starts at lower right it looks good and uniform.
The print progresses to the left and it starts to spread out.
I think it may be belt tension but I'm not sure.
Any help would be appreciated.
Thanks
Opublikowany : 01/02/2023 2:17 pm
RE: Smooth first print problem
looks like your bed is uneven, with the bottom right being the high spot. make sure the bed screws are tightened. try using the 7x7 mesh leveling if you have not done so. if all else fails, and you're feeling adventurous, do the nyloc mod.
IMO, it's better to err on the side of 'too low'. lower your Live-Z until the whole print surface is even. as long as the right side remains smooth, it's fine-ish
Opublikowany : 01/02/2023 2:47 pm
