self test error + x length + right x-axis motor doesn't lift
[Solved] self test error + x length + right x-axis motor doesn't lift
JD
 JD
(@jd)
could it be a bad motor? all of the motors are connected to rambo appropriately
https://forum.prusa3d.com/wp-content/uploads/2022/08/PXL_20220810_145845584-1.mp4
Posted : 10/08/2022 3:25 pm
Ringarn67
(@ringarn67)
the motor you refer to as "right x-axis motor" is Z!!!!!
NOT X!!!!
Double-, or even "triple-", -check your wiring again. Hopefully it is that simple 😊
Edit: https://help.prusa3d.com/guide/8-electronics-assembly_174100 step 34
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Posted : 10/08/2022 5:17 pm
And if it's still not working after you triple check, *temporarily* switch the connectors for left and right Z motors and see if the problem moves, you are checking whether it's a bad motor or a bad socket.
Posted : 10/08/2022 5:30 pm
Ringarn67 liked
JD
 JD
(@jd)
NOT X!!!!
I had the z and e connectors connected wrong on the rambo board. I also encountered a second problem during the self test. The heads of the zip tie hit the kinsy enclosure which caused an error so i had to rotated them a bit.  Also the x-axis motor is referred to as the z stepper motor however the motor itself is labeled as which is where the confusion came form. Their all labeled as x-axis, however that is not the case. Alls good now though woot!
Posted : 11/08/2022 4:28 am
Ringarn67 liked
