Self-test error X-axis length
daniel.t22
(@daniel-t22)
Hello,
I’m running the pre-flight checks on an MK3 and haven’t been able to get past an X-axis length error. I’ve removed some zip ties from the cables as suggested in forums but had no luck so far. I wonder if it may be an issue with the way I have wrapped the cable bundle and associated nylon filament (as in my attached photos)?
Veröffentlicht : 20/07/2018 4:29 pm
nathan0876
(@nathan0876)
Re: Self-test error X-axis length
What touches the end first?
The extruder body or the cable bundle/zip tie heads.
When i first assembled mine i had one zip tie head on the wrong side and ran into the same issue, all i did was rotate the zip tie to have the head on the other side of the cable bundle and it worked fine after.
Veröffentlicht : 20/07/2018 10:48 pm
daniel.t22
(@daniel-t22)
Thanks, I've removed a few zip ties from the cable bundle, but also discovered that the extruder wasn't on its runner properly – it's working now
Veröffentlicht : 23/07/2018 1:43 pm
