Replacing the X end motor-idler and tightening the X axis belt
Oram & Ram
(@oram-ram)
My x and y belts are loose so I tried to tighten my x axis belt with the tension screw on the x end motor idler, I tightened the screw too much and snapped a piece off.
I've got the replacement piece but I can't work out how to change it I think I need to remove the extruder then x axis, replace the piece then put everything back together following the assembly guide.
My main question is how do I remove the extruder? Do I need to open the electronics and unplug all the connections before unscrewing both sides of the extruder and removing it?
Thanks in advance!
Veröffentlicht : 22/05/2018 1:02 am
thrawn86
(@thrawn86)
Re: Replacing the X end motor-idler and tightening the X axis belt
Thanks in advance!
If you loosen the two screws holding the enclosure to the frame you'll have just enough room to pull out the plug for the x motor and then remove the whole x axis. I personally put the belt on before remounting the x axis. I also had to trim the belt a few mm because I went from the old style to the new style motor holder.
Veröffentlicht : 22/05/2018 1:34 am
