recovering failed print
so I have a 12 hrs print, failed with a crash. not really sure what happens as was at work.
the bed adhesion is good, the base of the print is good, looks like it only has 1 or 2 hrs go go to finish
how would you all suggest I salvage from here
1 forget it and start again
2 try editing g code removing all but the last bit and try to get it to print on top of what I have
3 cut the model and print the missing bit gluing the 2 bits together
options 2 or 3 will be a first for me and don't 100% know how to do either. but I'll give either a bash
thanks
Peter
Opublikowany : 16/10/2019 4:49 pm
RE: recovering failed print
Too late to forget it and start again.
Opublikowany : 18/10/2019 5:50 pm
3) is possible. 2) is not possible. Most of us would just write it off and start over.
Opublikowany : 18/10/2019 6:01 pm
