Prusa PC Blend - first tests and sagging
ChippyTea
(@chippytea)
First print with the new Prusament PC blend on my standard i3 MK3S with the standard settings from Prusa Slicer 2.2 which is the wheel from the PC Blend pictured pulley has sagged nearly 1mm from one side of the pulley to the other. I've tried to picture this but I don't think its as noticable on the picture as it is in real life.
It was printed with 15% infill so I'm currently printing another verson with 50% infill becase my first guess was that it was a lack of support. However, I wanted to post and ask how people are getting on with this brand new fillament and if people are experiencing this sagging as well?
i3 MK3S
Veröffentlicht : 07/06/2020 6:04 pm
ChippyTea
(@chippytea)
RE: Prusa PC Blend - first tests and sagging
i3 MK3S
Veröffentlicht : 07/06/2020 6:11 pm
Mitglied
Interesting.  I did not have the same problem.
Veröffentlicht : 07/06/2020 6:16 pm
ChippyTea
(@chippytea)
@charles-h13
What infil % have you tried? Are you using an enclosure?
i3 MK3S
Veröffentlicht : 07/06/2020 6:27 pm
Mitglied
I am using an enclosure.  I am currently printing at 40% infill but also printed at 20%
Veröffentlicht : 07/06/2020 6:32 pm
ChippyTea
(@chippytea)
So at 50% infill (rectangular same as above) there is much less warping/sagging that is doen to 0.15mm now which I guess is acceptable, morale of the story, print at higher infil ratios?
i3 MK3S
Veröffentlicht : 07/06/2020 6:43 pm
ChippyTea
(@chippytea)
Side note, I don't find I need the glue on the texture bed at all...
i3 MK3S
Veröffentlicht : 07/06/2020 6:53 pm
