PRUSA MK3S IR sensor lever issue
qczek
(@qczek)
Yesterday I build my first PRUSA and it works really good 🙂 Especially comparing to my previous printer ;-P
There is only one issue which I fixed using sharp knife, but maybe it's not only mine problem and could be fixed by correcting one of the extruder's part.
The problems is that top part of extruder hits IR sensor lever and pushes it inside the sensor's slot, which cause false positive sensor's readings.
see both videos
https://drive.google.com/file/d/1-oEl6sD9Yz8DVmcyYfEXiZmJk_i3yVf2/view?usp=sharing
https://drive.google.com/file/d/1-qiGzYhqowZhnMOlNf4vwg3CoR0SLPBz/view?usp=sharing
The solution is easy to apply 🙂
Before:
https://drive.google.com/file/d/1-gn2KbE7mg7mYLG2ZH994mT4Vt5n44rf/view?usp=sharing
After:
https://drive.google.com/file/d/1-dwJGWQecoY1_dbNtlT82kXA6EyeFKmi/view?usp=sharing
Have a nice day.
Kris
This topic was modified před 7 years 2 times by qczek
Napsal : 17/06/2019 8:18 am
1 lidem se líbí
MasterHead
(@masterhead)
RE: PRUSA MK3S IR sensor lever issue
Seems similar to the problem we were discussing in https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/filament-sensor-ir-problem/
Thanks for the photos and videos, makes it clearer to apply a solution 👍
Napsal : 18/06/2019 6:25 am
Brankomer
(@brankomer)
So you did cut a little bit of the C1 part? I dont see very good
Napsal : 20/06/2019 12:19 pm
qczek
(@qczek)
yes, indeed 🙂
Napsal : 20/06/2019 12:26 pm
Brankomer
(@brankomer)
I did the same, or I think, as it's not very clear on the pictures, but I still have this issue, when I push part C1.
Napsal : 20/06/2019 12:28 pm
qczek
(@qczek)
Posted by: daniel.m111
I just marked place to trim
https://drive.google.com/file/d/1Xoq10x76TWfqEdCw6ZSPJ2_LK9KVUUUa/view?usp=sharing
Napsal : 20/06/2019 12:36 pm
1 lidem se líbí
vladimirM
(@vladimirm)
I think I have the same problem. The files with the solution are not available on the Google drive anymore. Does someone have a copy?
Napsal : 13/01/2021 10:54 am
