Problems identifying my problem.
brandon-1
(@brandon-1)
Just finished building the prusa mk3s, and did 2 test prints that came out very sub par, and I don't know what is wrong, possible multiple issue? The Gcode for these prints were on the provided SD that came with the device, I did not slice it myself.
(in my ignorance at least) it appears to have issues with z wobble, and scaring? The printer successfully passed all the tests, checking the x,y belts are with in the proper tension range (245,262) , and I selected PLA as my filement profile (using the stock gray that came with it). If it was not obvious the gears print is fully seized with zero give.
Postato : 03/09/2020 11:32 pm
brandon-1
(@brandon-1)
RE: Problems identifying my problem.
My first post did not keep all the pictures I posted, here is the back to the prusa logo, and the finished gears.
Postato : 03/09/2020 11:39 pm
1 persone hanno apprezzato
jsw
 jsw
(@jsw)
Did you do a good Z calibration?
Postato : 03/09/2020 11:59 pm
brandon-1
(@brandon-1)
@jsw
I believe so. Is there a better way to quantify it other than the cross section examples in the book?
Postato : 04/09/2020 12:19 am
Jerry
(@jerry)
First of all
Love the title. Is it just me I can't see pics. I assume it is the nifty gear box .
It can take some force to get your first attempt started. Worst case is you break something you've proven you can make again.
Look at extrusion multiplier in filament settings.
Postato : 04/09/2020 3:10 am
jsw
 jsw
(@jsw)
Posted by: @brandon-1
@jsw
Yes, use one of those Z calibration test prints, such as any of several variants of the 3x3 pattern.
It does not take that long and is a good sanity check.  Those squares should be smooth and consistent across the print bed.
Postato : 04/09/2020 8:58 am
