problems adjusting PINTA
dogosforeverdad
(@dogosforeverdad)
do I have this right
I had real trouble trying to adjust this thing
The little red light does go off when its like this
Publié : 10/02/2021 11:46 pm
Robin
(@robin)
RE: problems adjusting PINTA
Hard to tell, the picture does not show the nozzle...
Home the z-axis->
If your nozzle ends up about 0.5-1.5 mm above the bed you got it right.
If nozzle crashes into the bed: PINDA too high ->lower it
If its higher than 1.5mm -> move PINDA up a bit.
As you see: Better start with PINDA too low...
Publié : 11/02/2021 3:45 pm
dogosforeverdad
(@dogosforeverdad)
@robin
thanks for the suggestion
now is there a way way to  make the PINTA easier to adjust
a another forum suggessted slighting enlarging the hole with a file or small screw driver
Publié : 11/02/2021 11:30 pm
Robin
(@robin)
What I wrote generally applies to the PINDA adjustment. Regardless of the way you fix the Sensor to your extruder...
Publié : 12/02/2021 8:41 am
