Problem with XYZ calibration
javier.s11
(@javier-s11)
This is my first 3D printer, the Prusa i3 MK3. firmware 3.5.1-1778
I'm trying to pass the first test. When I try the XYZ calibration, the test begin fine but when arrive to the "searching bed- calibration point 4 of 4" stops and show the message "XYZ calibration failed" Please consult the manual."
I have moved the PINDA in a lot of positions.
I have review the position of the bed.
I have review the belts,pulleys, ...
The nozzle is clean ( is new)
I have upgraded firmware to 3.5.1-1778
It seems well, ....but ... XYZ Calibration doesn't work.
Could somebody help me?
Thks.
Publié : 02/01/2019 4:29 pm
Rosparovac
(@rosparovac)
Re: Problem with XYZ calibration
Can you upload some photzos of your pinda, heatbed, and printer at all?
If its point 4 out of 9, it seems like wrong Y axis steps, because X axis pass at points 1-3.
University: MK2S upgraded to MK3 with MMU2.0
Home: MK3
Materials: ABS; ASA; PETG; PET; PLA; Nylon; Nylon Carbon; CPE;
SW: Freecad 0.18; Slicer PE And still generating more troubles than whole forum together.
Publié : 03/01/2019 10:08 am
RH_Dreambox
(@rh_dreambox)
Javier, we can't see your picture. Use the forum's features to attach an image.
Attachments, then Add files
Publié : 03/01/2019 4:26 pm
javier.s11
(@javier-s11)
Thks Rosparovac,
I include some Photos.
Belt Status is X-275 and Y-280?
Do these values ​​influence the validation of the XYZ Calibration test?
¿Must i tigthen belt X o Y to pass the test?
Thks
Publié : 03/01/2019 4:40 pm
javier.s11
(@javier-s11)
Publié : 03/01/2019 4:44 pm
javier.s11
(@javier-s11)
At Last, I solved the calibration XYZ problem.
To do this I, maked 2 actions:
a) I moved the pulley of the X-axis motor reducing the gap between the motor and tha base of the pulley (It seemed the belt was tauching slighly the plastic of the "X-end-motor printed part").
b) I tighten the X-Asis belt. With this i changed de value of the belt pression to 275 (before was 285) (Note: More index less pression).
Publié : 04/01/2019 9:06 pm
Well done...
Publié : 04/01/2019 9:11 pm
