Problem with XYZ calibration
This is my first 3D printer, the Prusa i3 MK3. firmware 3.5.1-1778
I'm trying to pass the first test. When I try the XYZ calibration, the test begin fine but when arrive to the "searching bed- calibration point 4 of 4" stops and show the message "XYZ calibration failed" Please consult the manual."
I have moved the PINDA in a lot of positions.
I have review the position of the bed.
I have review the belts,pulleys, ...
The nozzle is clean ( is new)
I have upgraded firmware to 3.5.1-1778
It seems well, ....but ... XYZ Calibration doesn't work.
Could somebody help me?
Thks.
Re: Problem with XYZ calibration
Can you upload some photzos of your pinda, heatbed, and printer at all?
If its point 4 out of 9, it seems like wrong Y axis steps, because X axis pass at points 1-3.
University: MK2S upgraded to MK3 with MMU2.0
Home: MK3
Materials: ABS; ASA; PETG; PET; PLA; Nylon; Nylon Carbon; CPE;
SW: Freecad 0.18; Slicer PE And still generating more troubles than whole forum together.
Javier, we can't see your picture. Use the forum's features to attach an image.
Attachments, then Add files
At Last, I solved the calibration XYZ problem.
To do this I, maked 2 actions:
a) I moved the pulley of the X-axis motor reducing the gap between the motor and tha base of the pulley (It seemed the belt was tauching slighly the plastic of the "X-end-motor printed part").
b) I tighten the X-Asis belt. With this i changed de value of the belt pression to 275 (before was 285) (Note: More index less pression).
Well done...
